This might not be the best solution, but it will work. First delete all old updates from the BC_VUP. Redowload the firmare update to your desktop and extract it there. Open the BC_VUP and cut and paste the .scn file there. You can then delete the other files from your desktop. Close the BC_VUP and reopen it. The box should display only the current .scn file. Click on it, then click on "open". If you can locate the folder into which you unzipped the first down load, disregard the redowload and just cut or copy and paste the .scn file into the BC_VUP.
