sjlamb
I have programmed (7) Group Quick Keys for for one of the Systems on a BCD396XT. The first 5 Group Quick Keys are for trunked groups, while the other 2 Quick Keys are for conventional groups. I have no problem toggling the trunked groups with their assigned Quick Key but, using the same procedure (function + . or 0-9), am unable to toggle the Quick Keys assigned to conventional groups on and off. I can see that they are programmed in the scanner and that all are enabled. What am I missing? Is there some trick to toggle Group Quick Keys when the group contains only conventional channels?
When trunked groups are toggled off, the Group Quick Key number is changed to an asterik to indicate that group is "off" and will not be scanned. The conventional channel Group Quick Keys show as blank despite that fact that are definetly programmed into the radio. I've tried to find something addressing this in the "manual" but no such luck.
