396xt Groups Workaround
appalachianscanner
Problem: If you should happen to de-select ALL of a banks groups there is an issue that you cannot re-enable the groups in a bank
(system)
Solution: (key path)
1. Program System
2. Select applicable system (bank)
3. Edit Group
4. Select any group
5. Set Quick Key
6. Change the Quick Key to a value different than its orignal value.
By default this will re-enable that particular group that you changed, then you can re-enable the other banks (Function + Group Number = Group on/off
Or just remember to never de-select all of a system's groups :)
UPMan
In Memoriam
Arlington, TX
A lot easier to F+Scroll to the system then F+GQK the key to unlock a group.
hfxChris
Dartmouth, Nova Scotia
Would be nice though if it prevented you from disabling all GQKs when all groups in the system are assigned to a GQK.
