396XT loose antenna connector
Anderegg
Enter text in this field
San Diego
The antenna connector on my 396XT rotates slightly and is wobbly. The problem is getting worse. I am assuming there would probably be some sort of nut inside the scanner that could be tightened? I was wondering if anyone has seen the inside of the 369, and could let me know this is a simple fix before I start tearing the case apart! :)
Paul
gewecke
Banned
Illinois
I don't have a 396xt so I won't be much help other than to suggest trying to obtain the service manual for it from uniden? I hope you have better luck getting one, than I did for my pro-106?
Maybe uniden will be more forthcoming than GRE. :wink:
73,
n9zas
davidmc36
South East Ontario
That's the "nut" right on the top. Try a small pair of needle nose pliers and put one tip in each slot and tighten. Or if you have a large version of one of the two prong screwdirvers that come with a cell phone tool kit. They would fit over the connector and into the slots.
Actually taking asecond look that one just holds the plastic on. There is another one under that holding the connector to the chassis. You will need to pull it apart quite extensively to get at it but it's not that bad once you get in there.
davidmc36
South East Ontario
Just be careful not to ubgger the threads.
Anderegg
San Diego
The whole lug can be rotated slightly to the left and to the right, as well as in a circular motion against the hole in the chassis plastic.. It stops hard in each direction, so it is not a tightening problem. I guess I will have to tear the lil bugger apart!
Paul
Anderegg
San Diego
I feel insulted that everyone thinks I am too stupid to operate a threaded connection!
Paul
gewecke
Banned
Illinois
Paul
Uh... I didn't think that at all? If I did it wasn't intended.
We were just trying to help.
73,
n9zas
Anderegg
San Diego
I'll have you know I worked on the O ring design for the space shuttle, I know what I'm doing! :)
Paul
davidmc36
South East Ontario
Paul
Paul
Well I will be sure and check for your lofty credentials before I open the case of my scanner to try and help. Like I am supposed to know that.
SC^$W YOU!!!:roll::roll:
How's that O-ring workin' out for ya!!!!
davidmc36
South East Ontario
Paul
In case anybody who is not a space shuttle scientist is interested, this is what you will find inside. The nut on top of the chassis (on upper side and not in view here) can come loose and allow the connector to rotate slightly in each direction until the flat spot on one side of it contacts the flange on the chassis, thereby stopping hard.
It would be wise to rectify this tightness problem before it works the connection loose on the PCB.
gewecke
Banned
Illinois
Paul
Well I guess your people skills weren't required huh?
You can just have the boys at NASA fix your scanner for you then.
n9zas
Anderegg
San Diego
THANK YOU THANK YOU THANK YOU!
I assume I just remove the back screws and it opens up like you see in your pictures?
THANK YOU THANK YOU THANK YOU!!!
Paul
davidmc36
South East Ontario
Paul
After that, you need to take out the six silver screws inside to separate the front half of the case from the guts. Watch out for the speaker wires when you take the front half off, they are pretty short and small.
rbm
Upstate New York
I bought a tool like the one in this photo a few years ago.
It was money well spent.
You can find them on ebay for around $9 shipped.
Search for: x-key tool
Rich
gewecke
Banned
Illinois
Paul
Please don't be a jerk to us next time! :mad:
73,
n9zas
GTR8000
NY/NJ Database Guy
BEE00
Paul
It's truly amazing that none of you in this thread picked up on his sarcasm. Not once did I think he was being ungrateful for the advice and help, or being a jerk. Some of you seriously need to get your sarcasm and humor meters calibrated, and relax (especially you, gewecke). :roll:
gewecke
Banned
Illinois
Maybe it was sarcasm, but he still ranked way up there on my jerk-meter from the way he replied!
I deal with people like this every day, so a little gratitude would be a surprise!:evil:
73,
n9zas
