The charging circuit is disabled when you move the switch inside the battery compartment to alkaline. It will say Charger Off on the display.
This doesn't really answer the question.
I have a 346XT. I believe when you start charging, it does a 14-hour cycle of charging. When complete, it says "Charge Complete", and I assume it stops charging. I have the following questions:
- At this point, is the scanner effectively running off the AC supply?
- If you unplug the AC adapter for a few seconds and plug it back in, does it start another 14-hour session, even for fully charged batteries, or does it sense the full battery and not do a charge cycle?
- If you unplug the AC adapter and partially use the batteries, when you plug it back in does it do a full 14-hour charge?
Basically, we want to know if the charger is at all intelligent, or if we should run the batteries all the way down before plugging in the adapter. The online User Guide does not give any details. I am not very familiar with NiMH - I use Li-Ion which has (actually requires) intelligent chargers.
I have also heard recommendations to only charge batteries in external chargers.
