So I live in the Broomfield area and I'm a fairly new user of the incredibly, amazingly awesome 396XT. Until recently I've been using my XT mostly to scan Public safety-related trunked systems in the Denver-Metro Area, namely local DTRS sites, Denver EDACS, Aurora EDACS, Lakewood P25 and Westy EDACS.
However I recently started running the scanner in conventional search mode on the 763-960 MHz range with the P25 NAC search filter enabled. Within a short time I began picking up a HUGE number of frequencies with NAC codes. All of the frequencies I've picked up so far come through very clearly, and it sounds like the radio units are all transmitting P25 digital voice.
My understanding is that whenever I'm running the XT in search mode/w NAC filter and I see a NAC code associated with a particular frequency, this always means I found a discrete P25 CONVENTIONAL Frequency (and NOT a "orphan" frequency belonging to a larger group of frequencies within a trunked system)? Is this correct? Because it sounds like I might be listening to individual DTRS site channels (or perhaps other P25 systems), but that doesn't make sense if NAC codes are only associated with Conventional P25 channels...
So far none of the frequency/NAC code combinations I found in the 763-960 MHz range are listed in the RR database. Take, for example, 851.9750/NAC D14 (hex). The RR database does list "851.97500" (with an additional fifth digit after the decimal point) as being associated with one or more trunked systems. But there is no 851.9750 listed with an associated NAC code.
