396XT & P25 Systems
W2SJW
Senior Member
Northwest NJ
Guys,
Just a quick question about how the 396XT handles P25 systems (this stems from a minor issue I was having using my new XT with Freescan).
Correct me if I'm wrong, but if you program a system as 'P25 Standard', you loose the ability to make these kind of changes via the unit's own menu system:
1 - The ability to set a system as 'CC-Only'.
2 - The ability to set a 'P25 Wait Time'.
3 - The ability to set the modulation format (always comes up NFM for the UHF systems here in NJ).
4 - The ability to set an 'End Code' preference.
5 - The ability to recognize status bits (I know that P25 systems do not use them).
I just want to make sure I'm not loosing my mind with this thing... :wink:
UPMan
In Memoriam
Arlington, TX
Correct, P25 systems do not require any of those settings, so there are no options to set them.
W2SJW
Senior Member
Northwest NJ
Thanks for the fast reply, Paul!
I was getting concerned that when I was reading the unit back in to Freescan, those fields kept showing up blank!
One last question - if I have a Moto-II 3600 TRS that operates almost 100% in digital & I have those TGID's set as 'digital only', should I be leaving the 'P25 wait time' at 400ms, or can I go lower than that (I've noticed TGID's hanging on screen & not passing any audio for quite a few seconds)?
UPMan
In Memoriam
Arlington, TX
P25 Wait time is ignored on channels flagged as either Analog or Digital Only.
al95
Brownsville,Texas
I hope upman answers rhe question asked on the next tread as fast as he answered this one for the BCD396T model scanner.
