396XT volume/control pot replacement
Anderegg
Enter text in this field
San Diego
I have a friend who is selling a 396XT with a faulty volume/selector knob. He says it turns, but that the electrical contacts seem to not be working right, because the volume and such jumps around while being adjusted.
I know these multi-function knobs don't stand up to much long term use. How much is the part from Uniden to replace, and how difficult of a job is it to repair myself? Are we talking soldering circuit boards? :-O
Paul
Ronaldski
MI DB Admin
Bay City MI
IMO may not necessarily be the pot but most likely the solder connections on the board. Had the same symptoms you state on a 396T.
The solder connections on the board are very close together and small so one of those cheaper basic soldering irons may not work.
I recall if I pushed to one side the pot white turning helped sometimes and rather deduced that it was a solder joint problem for me rather than the pot itself.
scanningisfun
Yes, you have to solder the part onto the board. The scroll control knob doesn't cost a lot at all. I have an extra one that I bought with a few other parts from Uniden. Like the other person said before me, the pins are very close together on the board; it will be tedious.
Part #: Rotary-BSRG0461001
Spring Plate-TSTD0200006 $0.50
Plastic Knob-GNBZ4B9810Z $0.25
Jacob
