396xt volume reset
AuntEnvy
Central New York
Hi all ~ Does anyone know if there is a way to prevent the 396xt from resetting the volume when powering on/off?
I have the batteries removed so it's only running on external power. I'm guessing that's the problem?
Thanks for any info
Turn the Scanner off with the Power Button, then back on, after that if you unplug or kill the Power to the scanner it will keep that setting you have.
AuntEnvy
Central New York
Thank you sfdf for the volume setting tip. That apparently did the trick. It makes things much easier now when I have it as a mobile setup.
It does make me wonder why it wouldn't have saved the setting before but no matter.
Thanks again
