4 tube elkin///
JayMojave
Mojave Ca
Hello Nitroturbo4U: I would think the power supply filter capacitors will need replacing, as a start.
Cleaning the tube sockets from dirt and dust, and making sure the relay is good to go, is a good call.
The Elkin Amps were neat amplifiers as there use those low cost tubes 12dq6, like you said. My neighbor ran one of these Elkin amps that had 6 of those tubes did about 160 to 180 (if I remember right). The good thing with this amp is that the designer did not have a driver pushing the tubes too hard allowing the to some what cleaner.
Good Luck, let us know how the restoration goes.
Jay in the Mojave
JayMojave
Mojave Ca
Hello Nitroturbo4u: Not having one I can only guess that the tubes are probably good for 30 watts each ( a ball park estimation) so 4 tubes x 30 = 120 watts PEP, so dead key at 30 swinging to 120 I'd say would be close. A stock CB at 3 to 4 watts dead key modulating to 12 to 16 would work fine.
This is a good bit of gain even tho its not a thunder and lightening high value of wattage amp.
The Elkin amp I say over at my neighbors place had a RF Power Level adjustment knob that he had turned down some to save the tubes from burning out. This guy ran this amp at a lower power level and always had it on with a good 5/8 wavelength antenna at around 50 feet high. Many of the locals said he was a Big Strap, but probably only had less than a hundred watts.
To double your range you need to increase you output power by 6 dB, than is a 4 times power increase. So a small clean amp will work very well. My 1959 Gonset G11 CB Tube Radio does almost
3 watts out, and works very well. Get a 5/8 wavelength antenna up high.
Jay in the Great Mojave Desert
