Scanner49er
- Joined
- May 15, 2006
- Messages
- 4
Recently picked up the Pro-2096 for the digital capability. I'm trying to monitor a 400Mhz system with two control channels. When in search range mode the radio hits on numerous clear voice transmissions switching from FM to DG. When I program the control channels into a bank the radio does as supposed to do, with all except audio. It is a 3600 baud system, Motorola. I have tried unsuccessfully to determine the offset and step size to hit on the correct frequencies for audio. I get ID's from three to five digits. Have tried setting the system to table, multi-table, splinter, and normal. As voice transmissions come thru in the clear when the radio is in search mode I don't feel I am listening to something I should not be monitoring. Any suggestions on how to hit the correct step and offset would be appreciated. Thanks in advance to help given.
