W4UVV
Recently I programmed the newer P25 Coast Guard frequencies in my Uniden 536. I was quite surprised today when I received a strong P25 signal on 412.9750 mhz., NAC 293. I had it listed as CG Sector Hampton Roads, Portsmouth "channel"? 409. Comms were infrequent i.e., every 15 minutes and appeared to be confined to contacting CG aircraft currently flying in its' control area for periodic position reports. I could not hear the CG aircraft(s) responses.
The CG Sector Hampton Roads transmitter appears to be using a high powered uhf transmitter for the Uniden 536 scanner's' Q5+/S 5 bar strength indicator..
I was unable to locate a graphic map for Sector HR's area of responsibility but the below link states it includes the lower half of the Chesapeake Bay to the Va. Capes 200 nautical miles out.
Coast Guard Sector Hampton Roads
John
W4UVV
John
W4UVV
