430-440 MHz Repeater Omni Antenna?
12dbsinad
Many decent brands. What gain?
RFS, CommScope, Commander Technologies, Telewave
Personally I've never been a fan of folded diaper poles but some people swear by them.
prcguy
Around here on 5k ft and taller mountains the ground is covered with fiberglass bits of what used to be antennas from ice and storms where the folded dipole arrays are still working fine. Also many fiberglass radome antennas like Stationmaster, SuperStation master and others by Sinclair are known to have internal dissimilar metal problems or mechanical problems where they get noisy after a number of years or create IMD due to corrosion at the dissimilar metal junctions. I don't hear about this with most exposed dipole arrays.
12dbsinad
Had a lot of issues with exposed phasing harness problems on dipoles w/ full duplex. Super station master are all copper elements. Essentially copper pipe with foam, soldered together. Usually crappy solder joints are the problem. And a upper support arm is essential if side mounting, many dont isntall one.
If you want a rugged fiberglass antenna, try a Celwave Bogner. Can withstand just about anything.
prcguy
SuperstationMaster has an aluminum support pipe screwed to both bare steel and brass and those junctions go bad at some point. I was discussing this with the current mfr Commander Technologies and they stated their antennas will develop problems within about 15yrs. Its a built in problem when you buy them new. A Bogner is way out of any amateur budget.
I am a lineman for the county.
I've got a couple of sites running Telewave dipoles that regularly see hurricane force winds in the winter, some ice loading (not a lot) and they've been up for years. I'm sure there's lots of good options, but those have really stood out as good antennas.
To be fair, my other sites don't see those kinds of winds or ice at all.
12dbsinad
I've had more problems with crappy coax used on folded dipoles for duplex use. Most are junk RG-8 type, non-shielded, braided. Exactly what we preach to NEVER use on any repeater. If you're running a combiner/multi-coupler then it's not really as much of a issue, but for true full duplex, 1 antenna, it's asking for problems. The other issue I've had with folded dipoles is falling ice above destroying the elements if it's not top mounted.
The stationmasters are not without problems, but most in my experience are mechanical. I have 40 year old antenna's that still work fine and are showing fiberglass hairs enduring Vermont winters. I've had some with noise new out of the tube.
