RadioFeed 436 noise weird
w9zro
NWI
Hello all i have had my feed up for years. but i recently wanted to add meta data to it.. when i plug the radio (uniden 436) into the usb port for metadata the feed is noisy as all get out. if i just run the feed without the radio plugged into the usb port and into the power supply no noise at all.. i have tried numerous cables and 3 diffrent computers. im stumped. i did try a search and came up with nothing any ideas
phask
zanesville
You need an isolation transformer - search, very common issue.
w9zro
NWI
thanks i read that and wasn't sure now i got to do more searching lol
w9zro
NWI
the noise is only when the usb is plugged in for meta data im gonna the isolator just for grins and giggles
w9zro
NWI
welp I think i figured it out i put more ferite chokes on the USB cable and also found out that the one USB port was only putting out 3.13 Volts so after i changed USB ports and the chokes it is better not perfect but better thanks to all for ideas
