436 we scan ?
kjfswkr
New Hampshire
Hi all,
Somehow my 436 got on weather channel and I can’t seen to get out of it. I have tried Function than Sys to no avail. Any thoughts?
Kevin
kjfswkr
New Hampshire
Hi all,
Kevin
I may have figured it out, somehow the wx got in scan mode. I hit avoid and it stopped. Not sure what I selected to ge5 it in with scan.
Kevin
jonwienke
More Info Coming Soon!
VA
Function - System doesn't do anything.
Hitting Avoid once will only lock out a channel until you reboot the scanner. Pressing it twice will make the Avoid permanent--the channel will stay avoided until you manually remove the Avoid in Sentinel or the scanner menu. Pressing System or Department first will avoid the entire System or Department, not just the channel.
You probably have National Weather Service enabled under Nationwide Systems in the Main Database.
