436HP AGC Question
jonwienke
More Info Coming Soon!
VA
I've figured out how to change AGC settings for individual systems, and for Close Call and quick search hits.
But I don't see any way in either Sentinel or the scanner settings to change the default for all systems at once. Do I seriously have to go through every system in the database and individually change both analog and digital AGC settings from the default Off to On?
Or is there somewhere I can go to change everything at once?
jonwienke
VA
On a related note, is there any global way to change the default system hold time and P25 decode wait time, either in scanner settings or Sentinel?
jonwienke
VA
Since the default is OFF, i'd like to be able to turn it on without having to individually edit umpty-hundred systems in the database. Once I get it to turn on, then I'll worry about tweaking its' settings. But until I get to that point, the rest is moot.
325xia
Rancho Santa Fe, California
I agree. I had to do this in Sentinel for the Delay too. Copy and Pasted in Sentinel to change this setting in each Group. Very tedious. Would have preferred one Universal Setting.
