My comment was on installing FW, and that you either install it, or you don't. You can't "sort of" install it.
Not sure you are getting the idea that anyone "sort of" installs the firmware?????????????
When I received my scanner, it had the latest firmware, so I have no idea about the mythical problem of "Conventional" receive taking some sort of hit or a loss in performance.
I will/would just call BS on this until someone can prove with test data that the firmware somehow caused any receive issue(s).
Unless there was some screwy clocking/intermod/birdie issue, the only thing that I think could cause a problem might be the selection of early stage bandpass filtering, the squelch behavior or the muting behavior. There were some changes to reduce a squelch tail that some reported and something with EDACS end tone, however, I cannot comment as I have never operated, owned, listened or compared a 436HP with a prior version of firmware.
I would just drop this foolishness and chock it up as an urban myth that you read one some forum on the Internet. You even stated the following:
Seems like good news about the overall conventional analog sensitivity.
However, I can't help but wonder about the large number of posts I've seen from users who experienced a DROP in conventional sensitivity after installing the new FW. What happened to these posters? Did they solve the issue? Did they just get fed up and walk away? Not sure. To the posters on this thread having good success with conventional sensitivity, what version of FW are you running?
How many people really claimed they had problems after the Firmware upgrade and where are they now?? I would assume it was less that half a dozen people and they probably have just figured out that they were imagining things or there was some other issue that was overlooked? Again, unless someone has a Communications Service Monitor test set that can take actual measurements and post the results with both versions of firmware, I would just totally ignore what was stated.
I would expect that about 95+% of the x36HP users are running the latest firmware in their radios. More reason to update than to stick with an earlier version in my opinion.
I will again caution that "Conventional" is a bit broad, I find the community seems to break down AM Aircraft and "Conventional" FM communications. I would want more specific details as to what modulation scheme and what frequency band anyone claimed they were having issues with.
