436HP - Downgrade Firmware
rickscholz
Anthem, AZ
I just upgraded to the newly released firmware, and ever since then I've been unable to monitor at least one trunked system... it doesn't even detect the control channels anymore.
It could be unrelated, but it seems like a good place to start... is it possible to downgrade back to the previous (released-not beta) firmware?
troymail
Silent Key
Yup - you can find firmware versions here (I also have copies saved off locally if needed).
Copy the version you want into the "firmware" folder of your SD card and on the next power cycle, the radio will load that version.
cellphone
Silent key.
Ahwatukee, AZ (Phoenix)
Based on the post in the AZ forum, I would take a look at your active systems and sites, services, and Favorite List programming(if using a Favorite List). This is likely not related to firmware.
https://forums.radioreference.com/a...44-maricopa-county-trunked-system-issues.html
rickscholz
Anthem, AZ
Thank you...
As others suggested, firmware didn't help. I didn't really think it would, but since it was easy to downgrade, I figured it was worth checking.
Thanks for posting the firmware archive. That helps a lot.
I have a couple other things to check, and will post further thoughts over on the Arizona forum if needed.
Rick
budevans
Cleveland, Ohio
What was the prior production version #?
I'd like to roll back my Firmware to the last Production version. Just to check a couple of things out. But I don't know what number it is.
Thanks.
hiegtx
Dallas, TX
Thanks.
The last version available through Sentinel, before V1_11_31 was made public (available through Sentinel) was 01_11_20.
brucebuck1010
Thanks.
1.11.20 was the last official firmware release prior to the 1.11.31 released last week.
-Bruce
