BCD436HP/BCD536HP: 436hp NXDN not trunking
mtnmadman
So Cal Mtns.
New to NXDN. Using ARC software programming. Cant get trunk track to happen.. (DFA NXDN multi site system) Tried different solutions, no dice. Im missing something here, help my small lizard brain understand. Maybe Im falling into my P25 programming too much or something.......
Randyk4661
Garden Grove, CA
Mobile Relay system off of Santiago peak
I listen to this system and this site as it has the ambulance company that OCFA uses .
The LCN's should all be set to zero, mine are in my two scanners. If they are already, then post a snapshot or post a file with how your scanner is programed with this system.
Currently I have the control channel 454.503125, is that what you are getting?
It's probably just a programming error.
Have you tried to download it directly from radio reference to see if it works?
You aren't confusing the LTR system with the NXDN are you? The LTR system is being or has been decommissioned and the users are being moved off the system.
mtnmadman
So Cal Mtns.
yes many times. Cant find any info on DFA sites. Set all LCN to zero. I know its a error on my part for sure. Just want to listen two acouple of talk groups
mtnmadman
So Cal Mtns.
Its the NXDN system for sure. Would like to program Heaps, but that site is dead to me. Get Crestline well
