I am having a great deal of difficulty understanding something.
I would like to preface this question with some information. I went into the Sentinel software and did this:
1) checked USA beneath database;
2) clicked on edit profile;
3) checked monitor full database;
4) click on all wanted service types;
5) put in the zip code under locations setting (zip zode previously saved as not there when I opened box);
6) put AGC for search close call, digital and analog;
7) nothing except pager is checked under broadcast;
8) next area previously programmed & saved was WX (the S.A.M.E. codes were retained from earlier);
9) all 99 quick keys were checked;
10 display welcome screen, previously programmed was retained;
11) clicked on save profile (nothing showed that it was saved, no box)
1) I turn on the scanner, plug in USB, hit "E", USB mass storage shows,
2) write to scanner clicked;
3) box is checked "erase favorites list on scanner" (there are none);
4) press ok
5) loading bar works;
6) click ok
7) unplug scanner
8) now loading Texas & full DB.
9) go to scanner and edit services which go back to earlier setting;
10) reset light duration, key beep volume, etc.
Back out of menu. Then, Waco Public Safety returns to scanning. This time, I did not go to "save location to go to Waco, the location I set inside the radio. It is now scanning fine.
When I turn this radio off, I will have to repeat these things in order to hear my zip code scan. When Waco Public Safety is missing during scan, there are no avoids in the review. Woodway P25 Trunking is showing up, no Waco. Getting analogs too. Range is showing default of "O." I had it previously set to 20.
I thought this radio would retain what I'd already saved.
Help me please.
4) press ok
6) click ok
7) unplug scanner
Help me please.
