436hp
bears3312
camas wa
alright guys i madeup my mind between 325p or436hp witch of the two are good need help to deside so i can order it
thanks bears3312 ps my taxes came
kd7kdc
Banned
kd7kdc
Banned
I have never had my hands on the 325. I have had the 396xt which is the same form factor which I find too small.
I have seen a lot of commentary on the forms that the 436 handles digital simulcast the best out of all the scanners available.
-Steve
lowboy654
DB Admin Member
Northwest, WA
I have a 436 as well as the 536 kind of a big learning curve to using theses scanners my everyday scanners are my GRE 500 and 600.
bears3312
camas wa
thanks guys stick with the 436hp get itREADY
when CRESA NEW P25 COMES LIVE
THANKS BEARS3312
nessnet
Eastside of Lake WA
436 - especially if you get the GPS - (or make your own via instructions found on the forums) and take the time to program the rectangles.
Hint: https://www.maptechnica.com/search?type=city
You can use this tool to define bounding boxes for cities, counties, states, etc.
Imagine your scanner changing to the right frequencies as you drive - no diddling around.
I'll give you an example:
Here is the rectangles already compiled for all of WSP's districts.
Dist 1
Pierce - 47.403675 -122.852918 46.728406 -121.374115
Thurston - 47.19422 -123.203101 46.762038 -122.203106
Dist 2
King - 47.780576 -122.541661 47.08435 -121.065945
Dist 3
Asotin - 46.462245 -117.47999 45.995357 -116.916071
Benton - 46.727763 -119.876725 45.836198 -118.94106
Columbia - 46.624777 -118.24264 45.99895 -117.603296
Franklin - 46.739105 -119.457535 46.192667 -118.198228
Garfield - 46.703168 -117.863347 45.997801 -117.228009
Walla Walla - 46.606812 -119.041498 45.999855 -117.991481
Yakima - 47.08875 -121.52307 46.040169 -119.86554
Dist 4
Adams - 47.261718 -119.369507 46.73539 -117.959335
Ferry - 49.000092 -118.869983 47.830363 -118.104447
Lincoln - 47.957906 -118.979777 47.260011 -117.819405
Pend Oreille - 49.001201 -117.629611 48.045394 -117.032107
Spokane - 48.047779 -117.823629 47.259272 -117.039763
Stevens - 49.000738 -118.402407 47.792295 -117.429967
Whitman - 47.260659 -118.249389 46.416779 -117.039405
Dist 5
Clark - 46.059632 -122.795963 45.543541 -122.244515
Cowlitz - 46.388045 -123.218313 45.850536 -122.239481
Lewis - 46.794427 -123.372706 46.383458 -121.353179
Klickitat - 46.045104 -121.612731 45.606098 -119.865829
Skamania - 46.388629 -122.25021 45.548653 -121.51438
Dist 6
Chelan - 48.550836 -121.180802 47.260871 -119.859708
Douglas - 48.151187 -120.318084 47.220133 -118.950592
Grant - 47.962183 -120.042866 46.625464 -118.972823
Kittitas - 47.597939 -121.465979 46.736151 -119.925605
Okanogan - 49.000569 -120.88564 47.940857 -118.836409
Dist 7
Island - 48.417855 -122.863078 47.828098 -122.328463
San Juan - 48.831218 -123.267877 48.284558 -122.703316
Skagit - 48.657003 -122.764404 48.295945 -120.686097
Snohomish - 48.29899 -122.458596 47.775349 -120.907399
Whatcom - 49.002432 -123.322238 48.625687 -120.655857
Dist 8
Clallam - 48.499784 -124.848974 47.866673 -122.896971
Grays Harbor - 47.533898 -124.429553 46.790916 -123.158364
Jefferson - 48.370361 -124.717153 47.517715 -122.595401
Kitsap - 47.972953 -123.038404 47.403091 -122.427023
Mason - 47.607508 -123.50608 47.082259 -122.8005
Pacific - 46.794241 -124.175131 46.234949 -123.357387
Wahkiakum - 46.385617 -123.728316 46.144532 -123.213054
bears3312
camas wa
Dist 1
Dist 2
Dist 3
Dist 4
Dist 5
Dist 6
Dist 7
Dist 8
thanks guys .my sis just order it she wont tell coming ill be happy when it does .can i listen to all state patrols on it
thanks bears3312 ps when she order it she had get an entanna for it spend 480 on it
bears3312
camas wa
My 436 came when I'll play with it get to know it let u know
Bears 3312
doublem
Oak Creek, Wisconsin
I recently upgraded from the BC246T analog trucked scanner to the 436HP. Listening quality and quantity has greatly improved. Aside from a few nuances such as not charging the batteries while using AC power or the volume control knob , it is a great device!!! Love it!
sparklehorse
Portland, Oregon
<snip> Aside from a few nuances such as not charging the batteries while using AC power or the volume control knob , it is a great device!!! Love it!
That's a good point. Like many here on the boards I recommend using a quality smart charger instead of using the radio as a charger. Have at least one extra set of cells, and use quality NiMH cells such as Eneloops. The Maha MH-C9000 is often quoted here as a fine smart charger. I've been using a La Crosse BC-1000 for five years now and have been very happy with it. The Eneloops I bought at that time are still going strong. I run a Discharge/Refresh cycle on them about once a year.
bears3312
camas wa
sparklehorse how do you have yours setup on your 436hp i just got mine wednesday ive very impresst with it
thanks bears3312
sparklehorse
Portland, Oregon
thanks bears3312
The programming architecture for the 536/436 isn't really all that different from the BCD396XT. The main difference is Favorites Lists, which are just a way of organizing systems. If you are happy with how you have your 396 set up, then I'd make one Favorites List and begin to organize your systems in it in a similar fashion to how you have your 396 set up. Start small, with just a few systems. Use Quick Keys and Number Tags in a similar way to how you use them on your 396. Once you get comfortable, make some more Favorite Lists, add more systems, start dividing things up. I like to have one Favorite List that contains a general scan list for the whole region, then a Favorite List for each County. But that's just me, you may have some other way of organizing that works better for you.
bears3312
camas wa
the programming architecture for the 536/436 isn't really all that different from the bcd396xt. The main difference is favorites lists, which are just a way of organizing systems. If you are happy with how you have your 396 set up, then i'd make one favorites list and begin to organize your systems in it in a similar fashion to how you have your 396 set up. Start small, with just a few systems. Use quick keys and number tags in a similar way to how you use them on your 396. Once you get comfortable, make some more favorite lists, add more systems, start dividing things up. I like to have one favorite list that contains a general scan list for the whole region, then a favorite list for each county. But that's just me, you may have some other way of organizing that works better for you.
need help my favrite list wont stay on im new with 436hp im confused help everytime turn on go to database witch i turned off leave fav on
doublem
Start by ensuring the service types selected in the profile are the service type you are attempting to scan.
