453.900
Mick
Western U.S.
In Colorado Springs I like to monitor the Pikes Peak Highway rangers on 453.900 who use 123.0 ctcss. Sometimes I can hear a distant user of 453.900 using 151.4 but cannot tell who they are since the signal is too weak.
The database shows Federal Heights Fire Department in Adams County uses 136.5 Hz on 453.900.
Phillips County is licensed on 453.900 and the database does not show them using it, so I hit a dead end there.
Is there someone near Phillips County that knows if they are currently using 453.900 and if they use 151.4 Hz? Thanks in advance.
datainmotion
Hoi Polloi
Colorado
Fed Heights FD has been using 151.4 for as long as I can remember. I believe the old PD dispatch channel used 136.5
