460.5375- Pumpkin Hill Ashford
jmanct18
Waht freqs does 460.5375 repeat? I thought I heard some one saw it repeats 33.80. I use to hear tones on it, but now I dont. Does it still. can some one give me info on this frew.
thanks
Joe
dittrimd
This is a repeater located on pumpkin hill in Ashford. It is a 4 channel scanning low band radio. It repeats 33.44, 33.78, 33.80 and 33.90 on the same pl with different pl inputs for transmit. In the future when this radio gets replaced it will most likely move to a multichannel cross band that does not scan. The scanning feature is good for people who want to listen to these channels but not very effective for operations since it will lock on to any acitve frequency with no priority. As of right now you should be able to hear 33.80 provided something else is not keying up the radio.
Hope this helps.
