460Mhz Base Antenna
kenisned
Unincorporated Arapahoe
I am setting up a dedicated scanner for a channel with the frequency of 461 mhz. This scanner has 25' of RG6 cable ready to be connected to an antenna, just not sure what antenna!
So, i'm looking for suggestions on an inexpensive dedicated antenna.
Thanks!
kenisned
Don_Burke said:
If you are willing to build your own, a j-pole is hard to beat for single frequency operation.
Hey, I'll try most things once.... and DIY sounds like my price range!
Any suggestions on websites that would have plans or a how to?
Don_Burke
Southeastern Virginia
kenisned said:
Considering that I am not using this to transmit, do I need the side element?
I'm clueless, but these seem to be built for transmitting?
You need the whole works.
They can transmit too, but then, any antenna can be used for transmitting at some power level.
