461.2125 Motorola system
FPO703
Planet Earth
I've been picking up a Motorola control channel on 461.2125 off and on for the past 3-4 weeks from here in Cleveland, Ohio. It's only when conditions are just right that I'm picking it up.
I'm also picking up a Motorola CC on 460.0625. But, that one has been identified and in the DB already.
Does anyone know what this one on 461.2125 might be?
IdleMonitor
The Ottawa Valley - Eastern Ontario
Well, a search on the Canadian Tafl which you can find at http://sd.ic.gc.ca Lists, H J HEINZ CO OF CANADA LTD. - Leamington, GRAND RIVER CONSERVATION AUTHORITY - Southern Ontario,
FPO703
Planet Earth
Now, if we can obtain the Motorola SysID, and other frequencies in the trunked system, we'll be in good shape.
DaveH
Ottawa, Ont.
According to THIS database, 460.0625 is the General Motors system in Windsor Ontario, SYsID 6637. The other frequency isn't in the database.
Dave
DaveH
Ottawa, Ont.
Anyway, I doubt 461.2125 is Heinz or the Conservation Authority because they are only licensed to the single UHF repeater frequency (amongst others that would not be part of a system). A 1-channel Motorola VoC system is hardly worth it for commercial use. Neumann Communications also in Windsor (VCQ656) is more likely with two repeater channels.
Dave
mciupa
Canadian DB Admin
Moderator
I'm here a lot
If it is H J Heinz in Leamington, two other freq's listed are 460.2125
and 462.5125 to go along with 461.2125.
I checked H J Heinz in Pittsburgh in RR's DB, they use an analog Motorola system with three channels as well, albeit in the 855 mHz range.
DaveH
Ottawa, Ont.
Yah, you're right, don't know how I missed it (must be the "tomato mystery" I guess). Those 3 channels are listed as 11kHz so narrowband by the look of it.
It still might be Neumann though. Someone closer needs to check it out...:)
Dave
