463.050 MOTOTRBO Indianapolis
W9NES
Indianapolis,Indiana
Does anyone know who the user is of 463.050 in Indianapolis?. I live not very far from St.Vincents hospital at 2001 West 86Th Street on the Northwest side. This used to be a UHF med channel on the old uhf ambulance to hospital channels in Indianapolis before 800Mhz IDPSC(aka MECA) was around. I have been hearing the classic noise of mototrbo on 463.050 for the past 3 months. A search of the fcc databse for 463.050 showed a old license for Wishard Hospital but that has been terminated.I did not find anything else in the local Indianapolis area.
INDY72
Indianapolis, IN
Sounds like an bleedover from another freq. Check for freqs close to that.... A lot of the Hospitals business freqs are now DMR.
W9NES
MILF, No bleedover from any frequencies .All frequencies in the the local area have been checked.There is someone on 463.050.
INDY72
Indianapolis, IN
Do you have any tapped scanner, or one you can run an line feed to unitrunker? UT now does DMR and NXDN to some extent. Or if you have a lot of time to play around with DSD+, you could let it loose on the repeater.
W9NES
Thanks milf for your post. I do not have any tapped scanners. I would like to ask if anyone on this forum that does have motorolatrbo or NXDN to check out 463.050 on the northwest side of Indianapolis and have a listen and report back to us on this forum.
