5-20-08 Lo Band SnoTel
techsender
N of St Paul MN
SnoTel 40.53 Data Very Strong into Minnesota at 0910 Central
Programming other stuff into the scanner now.
1/4 wave ground plane on the roof / 15 feet above the ground
RS Pro 35 Handheld
techsender
N of St Paul MN
The 40.53 freq is the base station transmitting out to the outlying stations. The outlying stations transmit back on 41.53 I think (this is from memory). The base trasnmitter uses a large antenna and several kilowatts and the outlying ones are at a few hundred watts with smaller beam antennas. I think the modulation format is published but I dont know if there are any decoders available.
