I am scanning my local PD on analog on my PSR 500, It will not stop on this frequency while scanning, If it's put on there manually it will work but not in scan, Is there a way to fix this, It stops on all other frequencies..
To which list did you assign this frequency? When you find out, press that number an it WILL be scanned. Remember, Scanlist 11 through 20 require pressing FUNC prior to number for toggling.It will not stop on this frequency while scanning, If it's put on there manually it will work but not in scan, Is there a way to fix this, It stops on all other frequencies..
Brian, I can't duplicate the problem, if you have software, try download from scanner and review CONV objects.Oh yes, It's in 4, The only one open, It won't stop on them if the ctcss tone is programmed in unless you click on them manually...It will however if you turn ctcss off or put it in search mode (But I get all the other far off noise) and my pro 97 stops on them everytime with ctcss enabled, What about resetting it?
Is there some reason you haven't updated to the latest firmware? (uP 1.5, DSP 1.3)Technical info for my unit includes the following: uP Appl Ver F1.1; DSP App Ver F1.1; DSP Voc Ver F1.0. I recently purchased the unit (new-original owner), and am still investigating it. Any intel./pointing me in the proper direction/etc. would be greatly appreciated.
Do to http://www.greamerica.com/support and download the latest CPU and DSP updates. There was an issue in early versions of the firmware (which your radio has) that caused problems receiving P25 frequencies with a NAC that started with a 3...Well, I'm now having a similiar problem with my PSR 500 not stopping on a frequency with a NAC tone stored. My case is Lakewood PD here in NJ. I programmed 453.6 with the P25 Nac of 398 and it won't stop on the frequency in scan mode with the tone programmed, nor will it let any voice filter through. In the P25 search mode, I have no problem detecting the tone and it stops on the freq. letting through any voice traffic. I have reset/initialized the scanner several times, but to no avail. It has also been noted that this only occurs with some tones, and not all. If I have the DHS FPSP 417.2 Nac 293 set, it works correctly with the tone stored. Technical info for my unit includes the following: uP Appl Ver F1.1; DSP App Ver F1.1; DSP Voc Ver F1.0. I recently purchased the unit (new-original owner), and am still investigating it. Any intel./pointing me in the proper direction/etc. would be greatly appreciated.
i have had this problem recently. our county fire repeater on 154.415 and our city fire ems repeater on 158.7525. the other conventional frequencies in scan list seven does not have the problem yet. i have a older pro 2006 and a pro 26 running in a other room. i can hear dispatch talking to units but not on the psr-600. if i manual on the channel i hear both dispatch and car. i just sent a note to gre about this.
