5200 Initial Programming using Bluetooth
SARRG
I have a new 5200 that shows UNPROGRAM.
I cannot get my PC ( Win 10) to recognize the kpg36 or 46 cables in USB or UART setting. Installed and uninstalled USB and VCP drivers many times. All the usual tricks that have worked with other devices in the past. Nothing happening with either cable.
D1 installed and activated ok.
Any way to enable the Bluetooth serial connection on a factory new radio so I can read and write radio via BT?
73
Peter
Sent from my iPad using Tapatalk
kd4efm
EL98 Florida
Simple answer, no. Did you order the bt serial port option?
What drivers are you loading?
I have been using the kpg36/46xm with win 10 in uart mode with no issues.
Did you use the disk provided with the cable?
If you do not have the driver disk, let me know, i will send you the link to fetch it.
Sent from my SM-G935P using Tapatalk
microx
Northeast Ohio
Keep in mind one of the settings (I believe it's the USB setting and not UART) you won't see anything in device manager at all when only the cable is plugged in. It's only when the radio is hooked up and turned on that something might appear. Try running D1N, and then plugging the cable in (I've also found that the particular USB port on my computer makes a difference, too. Try to use the same port all the time for that cable.) Once D1N is up and running, and the cable is plugged in, hook up the radio and turn it on. It is only then that a COM port appears in device manager.
The other setting (UART) of that cable, when plugged in, you should see appear in device manager as a serial port when plugged in and running correctly regardless of whether a radio is hooked up or not. (Mine comes up as COM4).
SARRG
Thanks for the quick replies.
I was getting a bit frustrated with Windows :)
No I did not purchase the serial BT option, but given all the issues I have with USB drivers in general, not just this time, I am thinking it might be a good way to go.
I finally got the cable to work on a different computer in UART mode. Nothing in USB.
I can read the radio information, but now have a new challenge. I received the attached error message when trying to read the radio data and save the initial radio read.
I am running KPG-D1 2.21
Experience with other manufacturers CPS but new to Kenwood. So first time with the FPU software and Kenwood ecosystem.
73 Peter
AYoung2600
Ohio
73 Peter
Sounds like your software version is older than the firmware version in the radio. You will have to update your software to the newest version.
SARRG
Thanks!
This is making more sense now.
73
Peter
