536 I can not download on channels from sentinl the scanner says nothing to scan .
Download sends the favorites list to the scanner. Monitor enables it to scan.Did you select monitor and download in the profile editor?
You need at least one favorites list programmed with at least one system or conventional object to be able to scan something other than the full database (zip code scan). Once said favorites list is added it then needs to be enabled to monitor: MENU > SET SCAN SELECTION > SELECT LISTS TO MONITOR > [select favorites list] : Onthe only way i can get channels in my scanner is use zip code
If the above measure fails to resolve issue, go through the items from the wiki provided in post #4. Start at subsection entitled "For the HPx, x36HP and SDS Series"Thanks but it is still saying nothing to scan
