536 issues
longfeather1
Chester IL 62233
Why when I try to program my 536 it always says "Nothing to Scan? Than when I have to put my zip code in to get it to work. Than it puts all kind of channels in the county around me. What i am I doing wrong .
enosjones
Price, Utah
Make sure your quick keys are turned on, and your services tags like law talk are turned on those aren't on by default unless u turn them on
enosjones
Price, Utah
Can do those functions in the scanner or on sentinel then write to the scanner, (make sure if u write to the scanner all the info is the same in sentinel as it is in the scanner or it will undo any changes u made on the scanner if its not backed up to sentinel)
drdispatch
If 1000 hertz, think what 1 gig must feel like
Fightin' River, Michigan
Also, if you are using Sentinel, make sure that you have the Favorites Lists that you want to scan set to "Download: On" and "Monitor: On" in the Favorites List Editor.
