536HP and ProScan
NYAirOne
Western, NY
Just got a 536HP to add to my shack. After unpacking it I see there is no audio out jack to run to my computer for ProScan to record from? Do you use the Ext Speaker jack??
Also for the radio to computer hook-up can I use the serial port with a serial to USB cable like my 996 series or do you use the USB jack on the 536 now? Thanks
Whiskey3JMC
DXpeditioner
40.0417240450727, -75.23614582932653
You need to use a USB-mini to USB-A cable for programming via serial mode, one should have come with the scanner unless you bought it second hand, this cannot be achieved via wifi. You can control the scanner and output audio via wifi without the need for the cable. Hope this makes sense
NYAirOne
Western, NY
Ok so I don't need any cables from the radio to the computer to use my ProScan software to run the radio and for unattended recordings. I do have the programming cable that came in the box. What is the rear USB jack used for?? They don't really tell you in the manual.
