mitbr
On the 536hp the scanner wont hold on the dept when the dept key is pressed if site hold is in place.
Anyone else see this?
Tim
Tim
Yeah, that's what I did. Not sure what I was thinking at the time... must be old age setting in! lolBe careful that the Dept and Site are not confused.
Site is accessed by Function/Dept button, different than Dept.
This makes sense and explains why you cant do this.As the OP said, you cannot hold on a dept and a site at the same time using site hold/dept hold since sites and depts are on the same level. You CAN however do what you wish by assigning each site a quickkey then turning OFF those that you do not want, then you would be free to do a DEPT hold while held on a site.
Hey that works!!I think I may have been wrong when I stated the above. If you hold on a DEPT first, you can then do FUNCTION DEPT and hold on a site. I just learned that!
