Hey guys, I want to chime in on this and give some feedback. I have 2 P25 systems I listen to, both Phase II. One of the systems is in the 450 Mhz range, while the other is in the 866 Mhz range....
Now I am using a Diamond discone antenna D3000N, and I get GREAT reception on the 450 Mhz Phase II system, but the 866Mhz one, I hardly get anything at all....Here is the kicker, I am getting a FULL 5 bars on the signal meter. Upon invenstigation, for some reason, under "Auto" in terms of the threshold level, the 450Mhz system locks on to 7 or 8 right away. The 866 mhz system searches all over the place. The antenna is fed via LMR-400 cable, water tight connections and up around 37 feet above the ground. I have been wrestling with this for months. Why am I getting a full 5 signal bars, but cannot get any transmissions? On the odd occasion, one will break through..
Now if I take the 436 Outside and put on a rubber ducky antenna, it comes in great!
cheers,
Jason
