5710 programing question
officerdave
Retired LEO
I was working on a 5710 we use as a control base. We are changing our PL tones on some repeaters and need to change out each 5710. I did a couple of car radios and then hit the control base. Programing seemed fine and then the radio went dead. Power button no longer functions . My guess is that I forgot our software is set to ignition sense for mobiles and I did not disable that feature when hitting the control base. Ok since I can not get the radio to power up, how do I restore the programing to get the radio back? thanks for any help
LATA 722
You need to apply 12 volts to Pin 1 on the 9 pin connector on the rear of the radio. That'll allow it to power up.
officerdave
Retired LEO
ok any PDF of the 9 pin I am not a tech trying to save the agency some money ( I know )
LATA 722
You can pull the +12 volts off the power supply. Ideally use a 3 amp fuse and connect it to pin 1. Depending on how your ignition sense circuit is programmed, the radio will turn on, or allow the power button to turn it on.
officerdave
Retired LEO
talked to techs yesterday .... I have to take the radio out of the control station chassis and pull the radio out. Thinking since the techs are going to adjust our other mobiles, maybe best leave it up to them. Thanks again guys for the help . I still at not great with the programing software.
