6-Inch Gold-Plated Premium Shielded Mono Y-Cable
Jeremy173
Moncton NB Canada
Any idea where I could find one of these cablse? It's the cable "A" in the forum for setting up your scanner station. I live in Canada so we don't have Radio Shacks and they don't ship to Canada. The Source doesn't have anything either.. Any ideas would be great.
fredva
Virginia/West Virginia
Don't know how much this helps you, but the use of that cable is the RadioReference-recommended way of setting up a broadcast station. There are other ways, such as getting a simple mono audio cable and running it between the scanner and the Line In jack on the computer. In that case, you would listen to your scanner through the computer's speakers to verify that it's working OK.
mtlfirebuff
Montreal, Quebec, Canada
You should be able to get the cables at The Source - these are the old Radio Shack stores. Or you can do what I did, I go to the U.S. often and when I was down there went into RS and got the cables.
