60 30 17 12m fan Dipole evaluation
ai8o
Brachiating Tetrapod
Lexington, NC
After doing some major tree trimming in my back yard, I have discovered that I have a 137 foot clear path between two 70 foot trees.
Assume:
1) That I attach the ends of a Fan dipole to each tree at about 40-50 feet.
2) that the fan Dipole sections are cut for the center of the 60m, 30m, 17m, and 12m bands
3) I use an Alpha Delta Delta C center and end insulator set ( I already have this)
4) 100 feet of RG-8X feedline
5) 12 gauge stranded copper wire for the wire elements
6) I will center the antenna in the opening using rope to connect to the trees.
7) the antenna will be oriented North-South (010-190 degrees) the antenna will be parallel to and approximately 40 feet from my already existing 80-40-20-10 fan dipole
8) my location is Grid Square EM95ut.
Questions:
1) what kinds of performance should I expect in each band?
2) what is the optimal attachment height of the antenna ends?
3) any other comments?
Dan
AI8O
prcguy
If your wanting the best low angle takeoff for DX that would be with the antenna at 1/2 wave or multiples off the ground. The first 1/2 wave for 60m is about 93ft and a half wave for 30m is about 47ft. A full wavelength for 17m is about 52ft and a three 1/2 waves on 12m is about 54ft. I would think an overall height of about 52ft might be a good compromise for low angle takeoff on 30, 17 and 12m with 60m being about 1/4 wave off the ground and great for regional NVIS coverage plus it will do some DX also.
