60 Second Key-Up
loumaag
Silent Key - Aug 2014
Katy, TX
Question for the Motorola guru's. While working with some of the people who are trying to figure out the South Dakota State System (VHF - 3.6K - 100% P25 Digital Audio) it was discovered that the voice channels at sites seem to key up every 60 seconds with what may be some sub-audible (as you can barely hear a hum) something. It does not show as a digital signal, and lasts about 1/2 to 3/4 of a second. All voice channels on the sites I can hear do it, including at least one alt CC channel that for some reason is not used for voice (but perhaps that is an equipment failure.)
Any ideas?
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I've been told that it's to test the output power from the repeater. The system can mark a repeater as bad before somebody tries to use it.
DaveH
Ottawa, Ont.
I've heard this keyup on a couple of VHF repeaters that are not
part on any trunking system, so it may be a newer test feature
on (Motorola?) repeaters.
Dave
WayneH
Forums Veteran
Super Moderator
Your master site
They started this after a certain version. All Motorola controllers will do it be it 3600 or 9600. It doesn't contain any info nor is there anything to do with it on the CC. Just for station testing as Mr Mike said.
-Wayne
loumaag
Katy, TX
Thanks Wayne, I knew sooner or later you would stumble across this thread and give me your usual defininative answer. :D
