600 help in nashville tn
maddgun
Castalian Springs TN.37031
need help from some one close to program my 600. be wiling to pay for your time..ive go it all messed up...i have 2- 30 day trails and when i try to up or down load to the scanner pc says unable to open port com 9 ??? have used 2-other pc an same thing.. is there any one near gallatin that would help me program this 600??
JLM7424
Williston,ND - Williams county
I Expierneced the same problems using the arc500 butel software www.butel.nl
First off did you install the drivers for the cable from your cd that came with the scanner
with cable plugged in to usb
using windows xp / vista goto: start button -> control panel -> system -> device manager
-> choose : ports(com & lpt) find something that says usb-to serial comm port.
double click it choose ports tab click "advanced tab" then change the port to 3
click ok . then restart your scanner software make shure you installed your usb drivers
from the supplied disk hope this helps /Matt.
