668 no sound
firecatohio
Logan, oh
Got no sound coming from radio... from either speaker or headphone jack....
Sent from my SM-N920V using Tapatalk
Wackyracer
Have you tried a power reset?
Unplug the scanner, pull all the batteries, hold the power button for at least 30 sec and randomly press any other buttons. Repeat several times if necessary.
Delta33
Clinton Iowa
Could be several things...
Try an Earphone to see if you get reduced audio? Also check weather channels to see if you get any audio from those? Also how about keypad beeps, any sound at all?
Wackyracer
Nothing works...
I have had the same issue twice, it took many power resets to bring the audio back. It would scan but had no beeps, no squelch, no audio on noaa.
Keep trying the power reset as your only other option is to send out to a 3rd party such as G&G communications in Leroy NY for repair.
