6m mobile antenna
What would be a good 6m antenna for the car? It needs to be either mag mount or lip mount for the trunk.
merlin
DN32su
My mobile 6 meter antenna was Antenna Specialist ASPA452. On a trunk lip mount that folded into the trunk.
It would outperform the 7' steel whip.
I could swap it directly with an M-125 tuned for 10 meters or the 2 meter version.
The antenna:
The mount was something like this: (Could be fixed to the hood lip also)
mrweather
A Larsen NMO50 works very well as a monoband antenna on 6m. But, you're get more bang for your buck with an NMO150 since it does both 2m and 6m.
VE7_Rover
I was speaking with NewTronics (Hustler Antennas) and was told the MO-1 and MO-2 masts are designed to be resonant on 6M.
I haven't tried it yet, but with an RM-10 resonator, one should have a dual band 6M/10M antenna. Ideal for those of us with radios that have 6M on the HF connector! Let me know your results.
mrweather
The NMO150 may not be designed for 6m but it happens to work there. Electrically it's a base-loaded 1/4 wave, same as the NMO50.
The NMO150 was only offered as a suggestion because it gives you the benefit of it working on two bands.
prcguy
The advantage is you will have a 6m and a 2m antenna in one antenna. The whip length will partially determine how well a dedicated Larsen VHF low antenna cut for 6m will perform against a 2m 5/8 used on 6m. I just dug out a 6m specific Larson and a 2m 5/8 Larsen and the 2m whip is about 4" longer than the 6m and that could give it a small advantage.
Is there an advantage to using the Larsen NMO-50 over the NMO-150 for 6m?
Cognomen
Radioactive Zone
This is great timing, because I was thinking of picking up a 6m antenna shortly, but I already have an NMO-150 not being used. :)
I'll dig it out, mount it, and will sweep it with a SiteHawk.
I actually don't need a 6m/2m antenna in one antenna; I use an NMO-WBQ140 for 2m.
jaspence
Michigan
6M is a strange band. If you haven't had experience with it, it can be frustrating. Having the 2M choice is a good idea, as it can be useless unless you are using it with a repeater.
krokus
Southeastern Michigan
If you get the Larsen 5/8 2m NMO antenna it will work about the same as the antenna posted above as a resonant 1/4 wave with a good match and its also a 5/8 wave gain antenna for 2m.
Sounds interesting. Does this antenna work reasonably well on 70cm?
mrweather
And I think the fact that the NMO150 happens to work on 6m is because the coil (VHF matching section) isn't DC grounded. I've come across other VHF 5/8 wave antennas where this isn't the case.
prcguy
The old A/S 5/8 wave with the grey PVC pipe looking coil was a tapped coil and DC grounded. The later black cone shaped A/S VHF 5/8 and Larsen and Maxrad and most others are not DC grounded. I've also used a newer A/S and Maxrad VHF 5/8 on 6m.
merlin
DN32su
2 meter and 70 CM are fine with VHF antennas because the are near a perfect 3:1 frequency.
6 meter doesn't multiply evenly so you get bad performance on 6 with any 2 meter antenna.
Likewise, an antenna tuned for 6 works poor on 2 and 70cm.
seeing is believing looking at a VNA.
I will put up screenshots when I get my puter talking to the VNA again.
I believe you are thinking of 1/4 wave antennas for VHF being 3/4 wave on UHF. That works well.
What they are talking about above is the non-DC grounded coil VHF 5/8th's wave VHF antennas being 1/4 wavelength base loaded on 6 meters.
1/4 wavelength on 6 meters is about 56-57 inches.
5/8 wavelength on 2 meters is about 49 inches, plus the length of the impedance matching coil in the base.
