bill4long
"It is brought into the repeater with 6' of RG-213."
That length is longer than a wavelength. Try swapping this out for some Heliax ASAP. Here's why:
For RG-213, the center conductor and shield have a different metal composition. This is a big no-no for in-band duplexing, especially at UHF frequencies. (It doesn't matter with cross-band duplexing.) Spurious frequencies can be generated that will desense the receiver. Heliax and hardline have the same center/shield metal composition and do not have this phenomenon. This is a well-known issue.
The Comet antenna should be fine, it's got about 7 dbd gain, which ain't bad, unless there is a defect in that particular unit. I have used equivalent antennas with mobile duplexers with excellent performance on UHF. Sidebar: use silicon tape around the N-connector after you connect the coax "permanently."
