chevymano
Hello all. I recently installed a new station alerting system in our firehouse and I have a bit of a noise/interference issue. But first, the background. We have a VOC system from fire alarm coming through a dedicated phone line to the VOC system controller which trips when activated from fire alarm. It then goes to a new 100w Bogen amplifier/mixer through the telephone/Vox tap so it will override anything being done on the amplifier/mixer. It goes out to 3 wall mounted speakers in the station and 2 loud speakers in the apparatus bays. The speakers and all are coming from the 70 volt taps. The system works great. Clear as a bell when an alert comes over. Now, we have 2 base radios. I cant remember what type off the top of my head, but they are for high band and low band radio for ours/surrounding towns frequencies. I hooked up the radios separate, but the same way: audio out from the radio, to a switch (2 pole/2 position) to select either a small speaker located in the radio room or select audio to the amplifier/mixer to be played through out the station and apparatus bays. When selected to the local speaker, it sounds good. When I select the station speakers through the amplifier/mixer I get a hum or something. Something like interference or noise through the speakers. How can i get rid of the noise/hum? Should I install a noise filter in the audio cables just prior to the amplifier/mixer? The power for the radios come from a ac/dc converter. The power cables are run somewhat close to the audio cables. They are separated as much as possible, but they go into the radio in close proximity. Let me know what you think and how I can solve this problem. Thanks for your input!
