700 lwin encryption
INDY72
Indianapolis, IN
Yes, for example, most of SELA Law Enforcement, now including NOPD, are strapped Full Time Encryption. Its not that much in use in MOST of LA, but in places where it is being used, its used big time. Lafayette Parish Public Safety was set for full encryption from day one of LWIN codeplug programming.
INDY72
Indianapolis, IN
The only TGs not allowed to have encryption are the Parish Interop/Coord's that are shared statewide. All other TGs can be encrypted as wanted by each agency.
And that is ONLY for the 4 original assigned to each Parish by the State GOHSEP. The others that the Parishes added onto those, they can, and some DO use encryption on.
red8
denham springs la.
Baton Rouge PD and EBR according to the data base have switched.
The dispatch channels on BRPD are using some encryption,while the other channels are full encrypted. On EBRSO, North and South Dispatch are using some partial, while the remaining is full.
Spec605LA
Statewide Radio Jedi
South East Louisiana
If you notice in the database the ones listed as "De" are select encryption. the "DE" is strapped encryption (full)
charlie12
Pride, LA
I listen to EBRSO North Dispatch and haven't heard encryption but have heard some on North Talk
WX4JCW
Stow, Ohio
its really sporadic, I'm really surprised Shreveport didn't go to the dark side, seems the encryption bug has hit the Cajuns worse than the north part of the state
