700 MHZ Interop & Tac Freqs
Tac-1
Linden, NJ
New 700 MHZ interop/ Tac Freqs
764.05625
764.06875
775.99375
794.05625
794.06875
805.99375
These Freq are licensed to Essex County and NJAG Office
does anybody know if these are National or for NJ only
Thunderbolt
Global Database Administrator
Moderator
Ann Arbor, Michigan
764.05625
764.06875
775.99375
794.05625
794.06875
805.99375
These are for nationwide use, and are available to all public safety users. :)
73's
Ron
Joseph11
Do you know if they're P25 Digital only or can they be used in analog too?
Audiodave1
Chadds Ford, PA
I believe all freq's in the 700 band will be digital only due to the bandplans channel bandwidth allocation.
Dave
902
Downsouthsomewhere
These three PAIRS of frequencies (there are three pairs, repeater and simplex - the LOWER frequency in 700 MHz is the talk-out/ talk-around) are available for nationwide itinerant public safety use and are ANALOG ELIGIBLE in 11K2F3E emission. That means they could be P25 or they could also be analog. Twelve channel pairs in all of the 700 MHz spectrum are the ONLY places analog is allowed. If you look at some licenses for this nationwide, you will see that some are licensed as 11K2F9W, or basically, any plurality of modulation types as long as they fit within the 11K2 emission mask - analog or digital. These channels are limited to no greater than 2 W and both XTS and XTL radios cut back their output power when these frequencies are programmed.
There are also 9 regional planning committee defined 2 W frequency pairs that are also analog eligible. These are primarily for on-scene use, like a fireground or tactical frequency, although some RPCs are allowing MO3 operation (mobile repeater - talk-in on 700, go out on another band and vice versa). These frequencies are site-specific and must be licensed in the area by the individual agency using them.
You'll probably be seeing more of these when the 700 MHz band is cleared. There is a stipulation on the licenses that requires non-interference: "Operation in the 764 - 806 MHz frequency band must be operated only in accordance with Rule 90.545 and must protect existing TV and DTV broadcast stations transmitting on TV channels 62, 63, 64, 65, 67, 68, or 69."
