700MHZ in an xts
thecanadiangod
Ottawa
Hey, I have an XTS 5000 700/800, some of the 700mhz frequencies have 5 numbers after the dot. for instance, 769.01375
the CPS will not let me put 5 digits after the dot.
How do I get around this?
nokones
Sun City West, AZ
I believe he is dealing with a 6.25 KHz channel and not a 12.5 KHz channel and may not need to put in the last (5th digit) and the CPS and the codeplug will probably assume the last digit is a "5" based on the channel bandwidth selection and the proceeding freq digits inputed.
GTR8000
NY/NJ Database Guy
BEE00
Uh, no. The issue has been resolved, it's a simple matter of setting the TX deviation to 2.5 kHz and has been discussed here in the past. What exactly do you think would be using 6.25 kHz in the 700 MHz band? Both P25 and analog narrowband FM are 12.5 kHz channel bandwidths, not 6.25.
nokones
Sun City West, AZ
Because it is an allocated 6.25 KHz spaced channel.
GTR8000
NY/NJ Database Guy
BEE00
I'll provide a bit more context for those unaware. Way back in the day when the 700 MHz spectrum was first allocated for public safety, the channels were created in 6.25 kHz blocks, as it was assumed that would ultimately be the bandwidth for P25 Phase II TDMA. As we now know, the bandwidth for P25 TDMA traffic channels is 12.5 kHz, and so for the past decade plus, the 700 MHz public safety narrowband spectrum has been allocated in 12.5 kHz blocks.
In fact the frequencies with 5 digits to the right of the decimal point are the 12.5 kHz allocations, e.g. 769.01875. The 6.25 kHz blocks result in 6 digits to the right of the decimal point, e.g. 769.015625
Bottom line: 2.5 kHz Tx deviation/12.5 Tx spacing is correct for the 700 MHz public safety narrowband spectrum.
