700mhz Trunking
Herm
Wheeling, WV
I have come across a moto control channel on 796.8125mhz. I have a Pro-96 scanner and when I try to get the sys id and the % nothing comes up. I have checked the FCC Database and nothing comes up. The CC comes in strong and I am in Wheeling, WV. Any help please.
Herman
_________________
Herman W
Wheeling, WV
That frequency would not have a control channel on it because that falls in the mobile TX spectrum. What you are hearing is most likely an image from an 800 MHz channel. The Pro-96 has a low IF frequency which makes the 700 band very susceptible to images.
Also as a side note, the Pro96 will not follow trunking in the 700 band because it doesn't consider the 700 channels as valid channels. And the sensitivity of the receiver in the 700 band is terrible on the Pro-96. So be prepared to buy a new scanner when the 700 band starts getting used (after someone makes a 700 scanner that is).
Colin9690
County 21
APE282018
What exactly will the 700 band be used for? Will it replace the 800 band. Sorry if this is a dumb question as we have been talking about this forever. How long will it be until cities start using 700 trunking? :?:
n4voxgill
Silent Key
New Braunfels, TX
does not replace the 800 band, the 700 MHz doubles the total available frequencies for public safety. There is 24 MHz and it will be used for all purposes. Once it is cleared of TV, it will be where most new systems are built or ones that can't expand now move to.
Colin9690
County 21
APE282018
Alright cool. I didn't want to buy a PRO-2096 for 500 bucks right before everyone started using 700MHz. That would suck.
Thanks!
