700p programing problem CONVENTIONAL OR TRUNKING VERSION ?
salonorg
CARY IL
hi iam programming a jaguar 700p and i have rpm R18B CONVENTIONAL .
does it matter if i program it with conventional or trunked version of the program ?
i have options for edacs groups and freqs editing
under trunked freqency set i cannot choose power or edacs bandwidth or the baud rate
does this matter for programming a edacs system ?
MrAstroSaber
Walkie Talkie Man
New Mexico
If you are going to program trunking you will need the trunking ver. I am almost sure of that. I may be wrong so don't hold it to me. I am running R18b02. Go to your help file at the top and you will see a tap called about programmer and in that window you will see a list of files. If you want to do eadacs trunking you will need edacs4 in that list. If you don't see it there or the ver. is blank next to it then you are out of luck. Hope this helpped you somewhat
salonorg
CARY IL
yup that is the version i have
yes that is the same version i have yes it says edacs4.exe r18b02 version r18brb02
is that able to program edacs ? is there any way someone could send me a pers file that has worked on there edacs system and i could just change the freqs and groups .
are the groups in afs format or dec ?
can i send someone my pers file to see what im doing wrong ?
MrAstroSaber
Walkie Talkie Man
New Mexico
Check your PMs. I sent you a message
