ok so i'm not a rocket scientist but....
I bought a PSR-800, 750-806mhz 9db gain Yagi Antenna & 45' of LMR-400 Cable to listen to PG Counties NEW X2-TDMA Trunking System. Where i'm setting this antenna up has a ground elevation of 118' above sea level (ASL) and the antenna is 30' Above ground level (AGL) so lets say 148' ASL. The tower is 6 miles NNW from my location and the antenna on that tower is mounted 340' ASL (40' Ground Elevation ASL and 300' tower). I can practically see the red light flashing from my antenna mount point. According to Google Earths Ground Elevation Profile Feature from Point A to Point B (A= My Yagi, B= Transmitter) its a total distance of 5.918 miles and the highest land point between A & B is 131'... I looked the whole line between Point A &B and there are no large buildings or any other obstructions between the Yagi & The X2-TDMA Site.
WHY CANT I GET A CLEAR LOCK ON THIS SYSTEM??? IM OUT IN THE STICKS NO OTHER TRANSMITTERS AROUND AND CERTINALLY NO OTHER TRANSPITTERS IN THE 770MHZ RANGE.
The owners manual for this antenna says to mount vertically but i have noticed that when I hold this antenna horizontly it performs better is there a diffrence because this system is TDMA?
Please Help!!!!
Please Help!!!!
