Yes i know, trying to work on that. I'm still trying to figure out how to adjust itThere are some who might tell you that your ALC should be less than half what you are running for FT8 on an IC-7610.
I'm running 25w now100W on FT8 as well?
In WSJT-X, it's the vertical slider on the right side of the window labeled "Pwr":I'm still trying to figure out how to adjust it
Yes i did not realized at first that the upper meter only indicates one value at a time.Looks like the meter is set to measure and read: View attachment 144342
That agrees pretty close with the Id in the reading below the meter:
Exactly..In WSJT-X, it's the vertical slider on the right side of the window labeled "Pwr":
